Dowel hole is too big, now what?
27K views 21 replies 9 participants last post by  DaninVan
So, i have a 1" dowel, and i drilled a 1" hole for a rocking horse handle.
Im not sure what the problem is but either the dowel is less than 1" or the drill bit is more than 1", but the dowel is loose. It does not fit snug. How can I correct this?
Many ways to get it to fit,,if you have a Japanese hand saw you cut a slot in the center of the dowel and drive in a thin wedge in,brass works well.
Or wrap it will some thick paper,the paper will take up the slop and it's real hard to see it after..:)
Note....most all the dowels are under size.:)
ha! Duh....i dont know why I did not think of splitting it and putting a wedge in it! Thanks for the tip, i will try it. Im not very experienced in wood working. I had thought of putting paper around it, but didnt know if that would be good enough. I suppose it would be, it will be glued and paper is made of wood...so why not.
Thanks again!
Hi
The paper will hold :),,soak the paper with glue tap it in the hole and wipe the glue off with some white vinegar and bottle water, a spray bottle works well, a 50/50 mix will clean the glue off...so you don't get that nasty blotch mark from the glue that likes to seal the wood :)
BJ if your a newbie I am in serious trouble!!:haha::haha:
#13 ·
HI Duane
I'm not making fun of you :)
I'm new just like all of us are ,,,...... I pickup something new every day from the forum :) that's why I stick around..:)
Quote from bobj3 - [ The paper will hold ,,soak the paper with glue tap it in the hole and wipe the glue off with some white vinegar and bottle water, a spray bottle works well, a 50/50 mix will clean the glue off...so you don't get that nasty blotch mark from the glue that likes to seal the wood }
Hold on 50 % white vinegar and and 50% "bottled" water -
does that formula have a residue cleaning effect on squeezed out aliphatic resins so that the wood will absorb stain afterwards that same as the surrounding wood. -- Is this something everyone know but Me ? ( which is often the case ! )
