Am I correct to think Downcut spiral bits cannot be used for plunge mortising? Only for full length slots or dados...
Can I force plunge them like I do with straight bit by dragging them along as I plunge?
Price difference between them and compression "mortise style" bits is quite high and the compression bits are not good for shallow dados so that means buying both
Down cut spiral will work for mortise cuts, just make multiple passes increasing the depth as you go. It doesn't Clear chips as well as an uncut, but the shallower passes will help with that
Are you wanting to know for handheld or CNC work, Mike? I use downcut spiral all the time on the CNC although I do my best to ramp rather than plunge (plunging is hard on the equipment). My ramps are steep, though, and typically 45° to 75°, so they're almost like a plunge but not quite as abrupt.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
