1 - 3 of 3 Posts
· Super Moderator
Font Rectangle Auto part Metal Cosmetics
For using the little stubby bits, I suggest you toss the quick change and invest in a few of the 1/4" magnetic hex bit holders. They come in different sizes. I have a tupperware box full of stubbies and several of the magnetic holders.
Cylinder Font Metal Titanium Auto part
· Registered
Here are the bits I purchased Amazon.com
Bits are great but the quick change chuck adapter broke the first time used . Any recommendations for an adapter? Now these bits I use on wood mostly haven't used on metal .
Your drill bits set suite a "driver"
Cylinder Gas Liquid Engineering Water
or a "drill-driver" which has torque control
Automotive lighting Motor vehicle Cylinder Automotive design Engineering
If you have a standard "drill" (without torque control)
you need a special adapter to use as a driver
e.g Makita P/N A15124 (as below)
Material property Cylinder Metal Office supplies Titanium
Assuming you have a modern drill driver
you may want to get this set
1 - 3 of 3 Posts
