I am finally finished with my drill press makeover. I had previously posted pics of my table. It is working great.
My drill press is a bench model w/ 3/4hp motor so it is kinda heavy and hard to move about. I have solved that problem.
The cabinet is made from birch plywood. It has a 1/2 inch back, and the top is made from a 1 3/4 inch solid core door covered with white formica. Very solid and steady.
I built drawers for the cabinet to store all of my drilling and sanding needs. I mounted the cabinet on a Harbor Freight mobile base. Now it is easy to move about as needed.
Note: Look closely and you will see my bench vise mounted on a one inch piece of Baltic Birch ( two 1/2 inch pieces glued together) and bolted to the metal base pf the press. That is working out nicely for everyday hack saw jobs. If needed, I can easily undo the carriage bolts and move the vise to my work bench and bolt it down and bang away!!!
Paint is Battleship Gray.
Hope you like it.
Hope you like it.
