1 - 15 of 15 Posts
Discussion Starter #1
If you have ever made a depth stop for your DP I would like to know how you did it.
I'm sure this is too simple, but if your DP doesn't have a stop, (why would they build one without) you could always use the table height adjustment
I can imagine how to make one depending on whether there is room between the handle assembly (spokes) and the casing. All mine is on my Delta press is a stop collar that locks to the shaft. If there is room for a collar to fit on the quill shaft then you could drill and tap it for a set screw bolt. Then you could drill the drill head for a pin or bolt for the set screw bolt to stop against. This would give you just under 1 full turn of the handle for depth adjustment.
Discussion Starter #4
Ronald it does have a depth stop but it's one of those that operates like a set screw but you hand tighten it. It might as well not have one.
Sorry Hawkeye10, I have limited experience with models other than my old Delta the stop is built into the pinion handle.
It depends what you already have on your DP. Mine is on the pull-down handle, others have a threaded rod with hex or knurled nut.
Which DP do you have?
Discussion Starter #9
Angie I have a Harbor Frieght DP. Their brand name is Central Machinery. The size is between a table top and a floor model. I have been looking for a good used DP for several months but so far I have had no luck.
Here's one I made last year but it's kind of tedious ........
I found this on YouTube some time ago from A Cut Above Woodworkings:......
There doesn't appear to be a depth bar on the harbor freight DP's. They use a collar on the pull-down handles center. I have the same problem, no depth bar.
Woodsmith issue 221 for October has the plans for a very nice depth stop that can also be used to hold the quill at a set depth, as for sanding applications. It is on my to do list. :yes4:
Discussion Starter #15
But I don't subscribe to Woodsmith. Can you post a link or picture?
1 - 15 of 15 Posts
