Clamping something down to a drill press table can be a pain sometimes, due to the webs under the bottom of the table. This is my solution. It can be installed or removed from the table in less than 30 seconds. I use it on a Delta benchtop drill press, but have looked at other drill presses and the all seem to have the same webbing on the bottom of the tables which make it more difficult to use clamps. Made from a 2x4' and a piece of 3/4" electrical conduit, it is fastened to the table with two. 6" J bolts. The work piece is held using leverage. This works great and would be an easy safety item added to any drill press!
