Nice. I like the guides on the sides.
David
David
I saw once where a guy took the crank off and chucked an old 1/2" drill motor on to the crankshaft, then mounted a 3 way switch in a box on the side of the table to raise and lower the table.Would be nice if there was a clever/cheap way to extend the crank out so the platform doesn't have to be moved to raise and lower it.
Shop Notes, I think within the last year of the stand-alone magazine, did a drill press table and used miter gears to locate the height adjustment to the front of the table. They used another set to do the same with the column lock. When I sent my old Craftsman RAS head in for the $100 bounty, I tore down what remained and salvaged one pair of gears (even the right bore for the height shaft). Miter gears are a little costly, but "free" wasn't bad. Need to find that issue again--that's a project i'd get a lot of use out of.Would be nice if there was a clever/cheap way to extend the crank out so the platform doesn't have to be moved to raise and lower it.
Shop Notes #135, May/June 2014, page 34.Shop Notes, I think within the last year of the stand-alone magazine, did a drill press table and used miter gears to locate the height adjustment to the front of the table. They used another set to do the same with the column lock. When I sent my old Craftsman RAS head in for the $100 bounty, I tore down what remained and salvaged one pair of gears (even the right bore for the height shaft). Miter gears are a little costly, but "free" wasn't bad. Need to find that issue again--that's a project i'd get a lot of use out of.
Wow--4 years ago??? Thanks for that, I need to dig it out and update my DP table. Great info on their source for gears too--just in case I can't find the set I salvaged from the RAS dismantling.Shop Notes #135, May/June 2014, page 34.
The miter gears they used are mineral filled nylon from Stock Drive Products & are $5.94 per set ($10 min order charge for orders less than $30, so $15.94 + shipping). Or from Amazon (ASIN: B004NYAFLS) for $21.95 each. Only one set needed, the column lock is just an extension of the locking screw.
jp
The crank assembly shaft on my dp is metric so I ground it down to accept a 1/2" coupling. Attached a bracket to the underside of the table with 9/16" hole that lines up with the coupling and cut 1/2" steel rod to length. Then mounted crank handle to rod. Works great!Would be nice if there was a clever/cheap way to extend the crank out so the platform doesn't have to be moved to raise and lower it.
You’re welcome. I had a chance to use mine today. It takes using one to see what you like and what you don’t. As far as surface area, I love what I have now! Wow, what a difference! I should have done this years ago. What I don’t like is the crank being in the way. A few times to move it isn’t bad in a project but today I was at it repeatedly and seemed to always need to raise and lower the platform. So I can see a redesign or an add on coming like what is in the other post I quoted below.Thanks for posting Duane. I really appreciate that you included all the photos; especially the view from below. I've been planning to make a really nice drill press table with fence & T-tracks (similar to Guitfiddle's) for years. Key word is "planning". As the plans kept changing trying to come up with what would be my ideal DP table, I've been using that miserable cast iron table on my 14 inch bench-top drill press and suffering with unsatisfactory results. Seeing your DP table brought home the point that I need to build something functional now, and worry about building the ideal table down the road. Thank you for changing my perspective. I'll copy your table and get it built this weekend so I can get using the drill press more often and with better results.
Michael C
This!!!!! And your DP is even similar to mine so I’m going to borrow this idea. I need this badly! Thanks for posting.The crank assembly shaft on my dp is metric so I ground it down to accept a 1/2" coupling. Attached a bracket to the underside of the table with 9/16" hole that lines up with the coupling and cut 1/2" steel rod to length. Then mounted crank handle to rod. Works great!Would be nice if there was a clever/cheap way to extend the crank out so the platform doesn't have to be moved to raise and lower it.
I made the table out of and old kitchen counter and some other material I had lying around the shop.
Sorry for rotation on first pic.
