Looking for recommendations for a better/ longer lasting brand square driver bit for Kreg pocket screws. Anyone? The Kreg brand don't seem to last too long without rounding out.
The original two Kreg bits that came with my kit which is about 10 years old are both in great shape. I think your right about making them cheaper. I use mostly #2 pan head screws from work for most all of my pocket screws which saves a Kreg pile, I mean a lot of money.I don't know they must be making them cheaper. I have the same one that I got with mine probably 20years ago and at least 3000 screws ago. It is a little rounded but still drives them just fine.
I looked at McFeelys, Very reasonable pricing.McFeeleys.com sells high quality long #2 square drive bits.
The proper screws have a kind of drilling property, be careful of splitting when using other screws, Marco. HD sells two sizes of 'no-name' screws (1-1/4" and 1-1/2") for soft wood. I put in mine with the clutch set a little loose and then hand tighten....I use mostly #2 pan head screws from work for most all of my pocket screws which saves a Kreg pile, I mean a lot of money.
Yes Kreg screws look like a self-tapping type point while the others don't. The others sometimes wonder from the center of the pocket hole but work well. I use Kreg on "Projects" and the others for everything else.The proper screws have a kind of drilling property, be careful of splitting when using other screws, Marco. HD sells two sizes of 'no-name' screws (1-1/4" and 1-1/2") for soft wood. I put in mine with the clutch set a little loose and then hand tighten.
I was able to find the name and part number from a "Good" one I use. It is made by Vega #1150R2AX #2 square Head 6" long bit Manganese Phosphate material Extra HardLooking for recommendations for a better/ longer lasting brand square driver bit for Kreg pocket screws. Anyone? The Kreg brand don't seem to last too long without rounding out.
