Welcome to the forum. Can’t help with you inquiry but I’m sure someone will be along to lend you a hand.
Hi Thank you for your help but everything you said went over my head, sorry I am 66 and this is so new after my stroke brain does not work, please try again for somebody that has no idea what you are sayingIf your DSP A18 is a handheld controller then it's made by RichAuto. What you need is the Post-Processor for that unit. The Axioms use the RichAuto controllers and the Post-Processor included in VCarve Pro saves the file out with a .mmg extension. Omni CNC should be able to provide you the Post-Processor, or you might try a Mach3 Post-Processor that saves the files out a .TAP file, or try a Post-Processor that just basic gCode. Or try the NCStudio Post-Processor. Looking at the Omni CNC catalogs it appears that the HandHeld controllers are using either NCStudio or Mach3 Post Processors. Hope this helps.
Is your controller handheld? If so, it's is probably made by the RichAuto company.Hi Thank you for your help but everything you said went over my head, sorry I am 66 and this is so new after my stroke brain does not work, please try again for somebody that has no idea what you are saying
