In another thread I described how I was able to upgrade from a Harbor Freight DC (running through a Dust Deputy) to a Grizzly G0440.
Prior to the upgrade of machine, I basically ran a hose to whatever machine I wanted to use. However, now that I have a "big rig" DC, I want to run ducting in my shop/garage. It isn't a complicated setup, really, but I want to get it "right".
The main input line for the DC is 7". You can buy the 'snap' ducting from Home Depot (et al) which is 30 gauge steele. These run about $12 for a 7"x5' length. The piece parts are also similarly priced.
While the G0440 isn't a monster, per se, I wonder if using cheap ducting like mentioned above isn't a mistake? It is *very* leaky stuff (which, I suppose, I can cover up with LOTS of aluminum tape) and is also quite weak.
I've looked around at various options for the "spiral" pipe (a step up in strength and air permeability) for at least the main runs. 22 gauge industrial grade spiral piping is $44 per 7"x5' length, but there is a 26 gauge hobbyist grade option (see airhand.com) that puts it at 31.75 per 7"x5' length. Yes, its spendy, but in reality will only cost about another $120-$150 over the "cheap stuff" to do my shop.
Does anyone out there have knowledge of such things to steer me into the right direction?
Thanx!
Thanx!
