I spoke with the support team at Incra. They made a couple of great recommendations for the clean sweep system to work for my new Incra Table.
They suggest a smaller dust extractor portable unit with a minimum of 400 CFM. I found a 600 CFM unit online.
Here’s a Myth Buster. As long as your using, the Incra CleanSweep insets 4 inch hose and a unit dust collector with 400 CFM plus, You’ll never burn up a router with the Incra CleanSweep system. The CleanSweep cools the router with it’s funnel design.
Incra has tested the unit with every router model that will fit the CleanSweep. As long as you have sufficient airflow it will never cause overheating.
