1 - 1 of 1 Posts
Hi Guys
I also have the 2hp HF setup,,and I use it on a 120 volt circuit with other tools running on the same circuit. I put a HVY.DUTY breaker in the panel and I have not snap the breaker once..I use the 3 1/2 HP router table on the same line all the time..:) with the HF running..it's that start voltage that will over load the breaker..I always start the Vac.system 1st..
So to say not all breakers are made the same :) (slow blow)
1 - 1 of 1 Posts
