welcome N/A..
take the brushes out and clean commentator......
With any luck it'll pop the breaker first. When ever I run into this no-go situation, I like to try it on a different plug on a different branch circuit, just to be sure it's not a house wiring failure.No fuses inside. When a motor can`t turn or is working too hard it experiences a current rise through the windings. Usually you have a couple of seconds before this gets critical in a full stall but the high current load is too much heat for either the wire size or the shellac insulation on the wire to withstand for long.
Had I done a little sleuthing I would have seen that the surge protector that it was plugged into did its job. It fried, not my router! Glad about that.:smile:
That’s great news. Hopefully you stick around and share some of your projects with usHad I done a little sleuthing I would have seen that the surge protector that it was plugged into did its job. It fried, not my router! Glad about that.:smile:
Hopefully not an expensive replacement?Had I done a little sleuthing I would have seen that the surge protector that it was plugged into did its job. It fried, not my router! Glad about that.:smile:
Check the schematics on any of your routers and locate that part.the motor should have a self-resetting overload protector built into it anyway. they work on heat, if the windings get too hot, it opens until they cool down..
you can't because it's sealed into the stator coil, you're not supposed to change that!..Check the schematics on any of your routers and locate that part.
