1 - 11 of 11 Posts
Hi all,
I am looking at buying the DW625E LX Type 6 and intend to use it for fitting a kitchen worktop.
Would this router be good enough for the job I want?
Thank you in advance
I think it would be right for the job. I have its baby brother, the dw621, and its all the router I need for most projects. The 625 is more beefier and more HP. Torgue would be a issue if it's not a slow start up.
The 625 is a pretty good router and so are the other DeWalts. I have a 610 and 611, both small ones. The only issue with a big router is the larger footprint and the weight. Sometimes a small one is better for small trim jobs but they are limited to small bits also. I and a few others say that if this is your first router then get a big plunge. It will be more versatile.
Discussion Starter · #5 ·
Thanks Cherryville.
I have has a few routers but I have never used them for a kitchen worktop. Just wondered if the 625e-lx was suitable.
I've used a Freud and a Hitachi as large as that. You don't usually need to. My little 611 will do most of what I need regarding counter tops such as laminate trimming and flush trimming the build up along the edges but the big ones will too, just a little harder to manhandle. For edge work using one of the big routers I find it easier if the router is mounted to an offset base of some type which includes the insert plate for my router table.
I have that model without the 'E'. It was the first 'big boys' router I bought. I cannot fault it in any way. I did, however, buy 2 other collets for it as the one that came with it was 1/2" and I have 8mm and 1/4" bits too. So I bought the collets for them. It's easy enough to switch them out and carry on routing. I'm still to add a couple of small led torches on it so they light up where the bit is going to cut but that's in the pipeline.
Harry Sinclair added one or two to his Makita 3612 Angie but that was quite a while ago when he posted pictures.
Reactions: richie176
The DW625 is a very suitable router for kitchen worktop jointing. I've used a DW625 and its' predecessor the Elu MOF177e for this task for more than 25 years and I must have done several hundred by now. The only downside, I'd say, is that te dust extraction isn't that hot
1 - 11 of 11 Posts
