Have you changed out the brushes? I think the most common failure is brushes. I replace them every two months on my DeWalt RO sanders (I used them that much) and I just replaced my 611 brushes the other day.
way to go Charley..I have 11 other routers,
Charley
Any hints on the best way to do that? I have the same problem.. DWP611 that probably has 30 minutes of use on it (but is over a year old) just decides now to stop consistently every 3 seconds.. It spins down to the point that the motor still growls, but it barely moves even with no resistance. I managed to finish the small job I was doing by turning it off and on again every 3 seconds, and it worked fine, but it's almost certainly the speed control.You can bypass the speed controller.
