Some may already know about this stuff. Easy Liner Adhesive Shelf Paper available at Walmart and Lowes and other places. Below are some pictures of the use of this stuff. The shelf paper works best on simple v carve projects. Complicated projects are harder to use it on because it gets shreaded up and small pieces can hard to remove. Not really hard but I use my finger nail and it sticks me and makes my finger sore so I learned to use a razor knife to lift it up. I had used Dewaxed shellac to seal projects before painting and still got paint soaking into the pores of the wood.
The first picture is the shelf paper applied to the piece of plywood I used for a test carve of a fairy
The second picture is after carving with a 90 degree VEE
The third picture is after painting with black acrylic paint with an 1/8 inch brush
The forth picture is after removing the mask and no sanding.
This was just a test carve in some scrap plywood. The results on red oak is pretty much the same.
