That is a really cool idea!
What I meant was a strip that was 1/2 as wide as the strips between the t-tracks. Basically 1/2 of a strip, not 1/2" of a strip.in your dialog, you mention a 1/2 inch strip on the outer edges to support your clamp - - The strip in the photo looks substantially wider then 1/2 inch?
Normally my cart with the PC and controller is right in front of the CNC with not enough room for me to walk or stand between so I'm never reaching over the bit rack. I have thought about making/finding something to cover the bits though, more to keep the chips/dust off the rack when I'm cutting anything.Im not sure of that setup for the bits. Nice but
I just caught a vision of snagging your wrist/forearm over the sharpies.
I have threaded inserts in the 1st layer of mdf. Hopefully I can mill the new pieces to line up with the inserts. I also have nylon bolts ordered.Well done. Mohawk!
To hold my sections down I used nylon screws recessed into the MDF about 1/4". Threaded inserts in the bottom MDF layer.
4D
