1 - 20 of 27 Posts
Discussion Starter #1
My wife has a little oak table that she picked up at the flea market. It did its job well for a couple of years, but then the glue in the glued-up top failed. The top separated into three boards.
The boards were joined together with a very old style tongue and groove. There was no way I could get the boards to go back together without removing the glue, which was a pain. Even then, I was never able to get the boards back together.
Since she told me I could trash the table if I couldn't fix it, I took my router with a straight but and removed the tongue on each piece by routing up to the edge using a Bora-type clamp as a straight edge. It took over an hour to get it right because I had to make sure the clamp was parallel and that I wasn't taking off too much wood.
After I removed the tongue, and took off a very small amount of wood on the groove side to make sure that the face was clean. That worked out well. Then I put biscuits in each side and glued the boards together.
However, when I joined the boards, the outside edges were flush, but there is still a tiny gap in the center of the table. The gap looks as if the clamp/straight edge flexed a little when I was routing. If you look at the clamp, I don't think there is a chance that it flexed. If I had bumped it loose from the ending side of the rout, the ending edge would not be correct.
Can you share any ideas about why there is a gap between the boards in the middle but not in the end? The gap is not bad enough to worry about, but it's clearly there. (I would have taken the setup to my friend who has a jointer, but the outside pieces of the table tap are glued to the legs and tray at the bottom, so that wouldn't have worked very well.)
My first guess is that the space that is there now may well have been the cause of the glue failure in the first place. Of course, that's hard to tell, but could be.
Did you do a dry run first? That should have showed up any potential spaces in those boards.
Premium Member
I would have cut off the tongues as precisely as possible, then routed a groove on each side of the board, then cut a spline to fit the groove, then glued them up with clamps and cauls. If the tongue is cut with all boards face down on the table, the top should wind up flush and any sanding to level the underside up would be on the bottom, out of sight. The cutter for the groove would have cleaned out any glue, and you could make two passes to widen the groove slightly . With a trial fit, you could tell where the gap was, then use a hand plane to straighten out the piece(s) until it was a perfect fit, then glue. You would still have 99 percent of the full width when you were done.
Premium Member
BTW, you could still cut the pieces apart with a very straight rip cut down the line of the gap. Need to set such a cut up carefully and use a glue line type blade. Then you will have the same as a planed, straight edge that can be re-glued. Use a narrow kerf rip blade. I'd use my narrow kerf, Freud Glue Line blade for that after making certain my fence was a close as possible to parallel with the blade. And I'd double check with a Wixey digital gauge, to make sure the blade was exactly 90 to the table. You will likely lose about the same width with this approach as with a hand plane.
I think his question is more on why did this cut end up this way it did when the guide is stick straght, why didn't the cut mimic the clamp guide?
First, even if you push that saw tight against the clamp and know 100% for a fact it stayed super tight against the clamp the blade can wander. It wanders very, very little in these cases and most likely caused by the wood itself , either from an internal stress or grain characteristic that the blade just had to follow.
Second reason is near the first except the wood caused the saw itself to wander ever so slightly in the same manner and reason described for the blade. The saw left the clamp or the saw titled ever so slightly as you went from end to end.
This is why the track saw was developed. A track saw keeps the saw perfect straight and eliminates the saw from wandering due to wood stress or the saw leaving the edge of a guide. But I have seen blade wander even using a track saw, especially with a thin blade.
Also, unless a person is very skilled and the set up, saw, blade and wood(plywood is far better than hardwood) all perfect the method you used is never an ideal nor easy way to get two boards to line perfectly. The Bora clamp method is great for squaring things up, but joining or jointing two pieces calls for more precision than a setup like this offers. Still, if you used a track saw you would have had a far batter chance of getting good results.
One more thing, the wood could of actually moved after you cut it. Don't laugh, the stress in wood causes this all the time.. I make pieces that consist of geometric shapes and I cant cut the parts unless I know I can glue them up the same day for this very reason. The next day the pieces wont fit flush with a jointed like seam. The longer the parts are the more likely this can happen.
You only took a fine shaving off either side at the most and that shouldn't be enough to affect the boards tension. I'm not familiar with the Bora but it would need to be pretty stiff to eliminate that as a possibility and in fact, the problem occurred where it be most likely to if the straight edge were the problem. Its too bad you didn't find the problem before the glue up because it would have given you a chance to try to find the cause and fix it. Anything we can suggest is pure conjecture at this point.
Reactions: cocobolo1
Hey Mike, before I would repair the table top first I would want to know why the boards came apart in the first place. Look under the top to see if the top was screwed to the frame or apron in such a way as to prevent the top from expanding and contracting with the change in humidity. If that is the case your repairs will eventually fail.
As far as re-gluing the boards, I'd run the edge of the boards over the jointer to cut away the tongue and grove then put Tite Bond II glue on the boards and use pipe and or belt clamps to pull it together. I have repaired 4' round tables this way. On one table the top had failed because there were lag bolts holding the top to the frame preventing the top from expanding and contrasting.
Malcolm / Kentucky USA
Discussion Starter #9
Thanks for all of the suggestions and comments. Let me reiterate that the only power tool involved was a router with a straight bit. I don't have a track saw, jointer, or table saw. Only the width of a tongue was routed off of each of two boards. When I did a dry fit, it wasn't perfect, but it was good.
It's not important for me to go back and do any more work on this table. It's serving as a learning experience so that I can hopefully understand what I'm doing when it does matter.
A couple of possibilities; first, is the clamp actually straight - do you have a true straight edge for checking it
Second, it is possible that the clamp flexed in the middle when you applied pressure to the clamping mechanism.
Discussion Starter #11
Both are possible, but I have not been able to prove either one. No, I don't have a true straight edge, like a Woodpecker, but I have a lot of straight edges. I'll do some testing with the clamp today. It seems impossible to me for the clamp to flex because of its design. However, it's possible. clearly I don't know what the problem is. What is good is that the edge that I routed most aggressively is the one that fits best. I have to learn not to be afraid of the wood.
I misread the post about a router only being used, I knew you had no track saw, still riding router against an edge freehand isn't the ideal way to do it( i did it so many times back in the day with mishaps). Bora sells an attachment for some off their clamps to firmly attach a router that would have been better.
If you truly only touched the tongue the clamp being bowed cant be the issue, but that is a problem. You would have have been better served taking a hair off both sides down the entire length of the boards to ensure a nice flat, square straght cut, with a consistent fresh edge all the way down. Most likely where you cut the tongues the cut was perfect, the rest not so much. Leaving areas that were only scraped of adhesive and fresh cutting the tongue parts could possibly be an issue for glue up. We can't ever do a glue up on a joint where part of the edge is fresh cut and some of the edge isn't, that may be why this happened, either from uneven adhesive absorption rates along the edge or you simply thought the fit was perfect and it wasn't.
I use Titebond III for things like this and I have hidden gaps up 1/32 with it when clamping, something Titebond II and most other adhesives of this type simply cant do., I think if you used a different adhesive and the gap was very slight the adhesive could of hidden it.
The problem with one off operations like this is that we will never know why it happened for sure because you wont be doing it again to sort it out. I am sure it looks great as is, we tend to be to critical of our own work. The wife and friends probably don't even notice it nor care.
Discussion Starter #13
I think you have figured it out. It looks like I only routed the tongues on the bowed edges. Duh. Thanks for your critical thinking!
So Titebond III fills joints? I've struggled with which one to use, so I've purchased regular Titebond and Titebond II. Now I have to get a bottle of III. Live and learn.
L.V. 202GF glue
The Lee Valley 202GF glue works for this. The "GF" stands for gap filling.
Titebond has a chart on their website that shows the solids content in the 3 Titebond glues as well as open times, strength, etc. The higher the solids content the better it fills gaps. It's much like adding fillers to epoxy. The LV 202GF glue is every bit as good as the Titebond. I've used it before but you do need to keep the solids stirred up which you probably should do with the Titebond too.
Titebonds claim of waterproofness is nothing more than a sales gimmick, one that they've been very successful with. If you need a glue to be that waterproof you should probably be using mechanical fasteners to hold it together instead of glue.
I don't suppose a pic of the area would help? I have a couple very old 2' and 4' straight edge clamp bars and an interlocking set extending to 8'; I can say that all but the interlocking bars have slipped at some point in a milling process. The interlocking set uses "C" clamps to fix the ends of the bar in place. When my clamps have slipped it was due to excessive pressure against the bar during the milling process and the resulting cut was not symmetric. To date I've never had any of the 2' and 4' clamps flex in the middle.
If I understand and interpret Patlaw correctly then flush at the ends = tight joint not uneven joint. Tiny gap in the center = sides do not touch? How tiny is the gap and how long? Without seeing and if no one has already suggested, it sounds like a spring joint to me, intentional or not. I'd try to verify the accuracy of the bar with something else like a 4' aluminum straight edge measuring stick or 4, 6 or 8' stabile level. Even a tight weave line stretched taut over the length of either side would show a bend in the clamp by eye or feeler gauge.
I've not heard of those being called bora clamps but I have a set and hate them. They are very hard to get to clamp tightly. The problem is the cams have a very short range of motion and you have to get them really tight before pushing down on the lever.
I use pipe clamps and cauls instead.
I agree,Phil,I invested in a couple a few years ago and after the first few tries, I gave up and went to the boards and clamp or the saw guide I used for cutting bottoms off doors.
I'll agree w/ ya that the Bora brand clamps suck...
and the usual PDF's on glues/adhesives.....
I beg to differ about the waterproofing for the Titebond III.
The claims about the adhesive are not over stated in anyway.
I have tested Titebond III extensively as I must be sure my work used in exterior boat and ship decks won't fail. In 15 years I have had ZERO failures of the Titebond III being used in a boat deck application. It's waterproof for it's intended uses.
I also disagree about a mechanical fastener. Take two 12" by 12" wood pieces and use 20 screws to keep them together. I will pry it apart with a chisel dry, get that thing wet and a week later those screws will be failing, the wood will shrink away, the fasteners fail. All a screw is good for is to act as a clamp until the adhesive dries. The same two 12" pieces of wood glued together with Titebond III is simply impossible to pry or tear apart. I have tested this and the only way is to literally drum sand one board off . I actually have picture somewhere a subcontractor tried to get one of my marine ply backers off that was attached to hardwood using Titebond III in a vacuum press, they failed miserably. And this was after the thing sat in the wet weather for a month. They had to send it back for me to toss through the 50" drum sander.
The Titebond III has stood up in exterior deck work in the Chicago area. 10 years ago I edge glued joints with Titebond III, they are still holding and have no separation to this day. I have boiled two parts glued together, baked them in an oven and boiled them again, no failure. I have left pieces outside for so many years I lost count, and the parts are still holding. If this adhesive fails, it was either not used correctly, possibly someone had a bad batch or didn't mix it right, it has always stood up to water for me. It isn't for gluing the hull of a boat together, but for joining parts that get wet and not constantly submerged it's a dream adhesive.
Titebond III is far stronger than any mechanical fastener if the point is to stick two things together. It's not for structural use, but then again only certain screws of certain material and sizes are structural.. And woodworking screws aren't generally structural anyhow. Screws of course have their uses, but when adhesive is appropriate for the application it is is always better than a screw.
To stick two things together in an area outside with excessive water Titebond III has worked just as well as the West System Epoxy. Its characteristics are far better than any polyurethane adhesive and simply stated Titebond III is the best all around simple to use adhesive in the world.
I can only go by my life experiences. I go through 100's of gallon of West Systems epoxy and Titebond III a year and both work as advertised, no Gimmicks.
1 - 20 of 27 Posts
