Ok guys here it is for anyone who has the need to strip down the Elu router. I can only vouch for this being correct for the Elu 96MOF but I am sure most of the other clones will be about the same.
Well the top cover must come off first of course. Lift off the speed sensor from the posts where the screws locate. No need to remove the wires from this just let it hang over the side. Remove the brushes by undoing the two Phillips screws either side of them remove the plastic retainers then pull on the wires to lift out the brushes. Watch they dont spring out! Remove the wires from them and put to one side. Pull up and wiggle the small speed sensor pickup from the top of the shaft. (It is splined onto it)
Remove the phenolic baseplate carefully as this retains the return spring and lift out the spring from the right hand post. Unscrew the switch from the side of the router and jiggle it loose. (It is located with a lip into the bottom casing)
plunge the router to full depth and below this you will see the top of the post with a circlip on. Remove this clip then lift the router casing off the base plate.
Now remove the four screws in the housing surrounding the bottom end of the armature shaft and remove the spindle lock housing oh and remove the collet and nut to allow the armature to slide through the hole. Now I removed the screw plate surrounding the end of the armature but I don't think there is any need to do this but remove the four screws holding the top of the motor casing to the alloy base and then pull and joggle the two apart.
Inside you will find the fan assembly and make a note of which way around this goes as it looks like it could fit back either way but in fact will only fit one way around. After the base is removed pull the armature from the upper casing and you will see the top bearing in place on the shaft.
I jury rigged a half moon affair to sit under the bearings while I gently tapped the shaft with a thin punch so as not to mushroom the end over with a thick cloth below ready to catch the armature. The bottom bearing is located in the lower casing and is held in place by four screws and a collar.
Remove the screws and then drift the bearing out from the front of the casing, (It does not matter drifting it on the inner race as it will be replaced) Drift the new one back in on the outer race of course with a socket of the right diameter and re-fit the collar and screws. drifting the upper bearing onto the shaft was done with a long BA socket located on the inner race and tapped gently down into place.
Rebuild of the router is a reversal of the disasembly and is straight forward with no hitches that I found. Replacing the brushes was a little fiddly as there isn't much room to get your fingers in but I found a pair of thin needle nosed pliers of help here. If you go to this site:
Tool Shop Direct - Where Tools Cost Less and navigate to spare parts/elu woodworking/ routers/ MOF96E typeA you will find the spare parts and also an exploded diagram of the router which came in handy not having seen inside one before.
I paid around £16 for both of the bearings and delivery was quick. I must get in touch with them again myself as I need another fine height adjuster for my Trend clone. I can certainly recommend their service as I have used them on a few occasions now.
Oh and by the way I found that placing a piece of white paper on the bench and laying out all the parts in their respective locations helped a lot with the re-assembly.
