I'm not sure where this should go but here is where I'm putting it.......
BobandRick I see you use the single bit to make the pass down the veneer material. Then you lower it and do the two passes to make the molding. If that is one bit then the top gets used to do all three cuts to the bottom half of the cutter which does just one cut. Is that correct?
Now the real question, is there a reason why you use the butterfly bit over a matched set of edge v-grooving bits?
Ed
Ed
