1 - 2 of 2 Posts
Discussion Starter #1
I will be building blanket chests in The Netherlands using solid hardwoods. I would like to make sure I order the proper wood grade for this furniture. So far my research has led me to believe that the proper grade would be A1 but I am not sure.
The wood I will use will be about 18 mm and 24 mm in thickness. What are the industry standard thicknesses in that range before and after planing?
Hello Bob
I don't know if this helps or perhaps you've already seen it but I found this link.
http://www.forestry.gov.uk/pdf/MTG-WEB.pdf/$FILE/MTG-WEB.pdf
Just copy and paste it in your browser.
I hope it helps.
1 - 2 of 2 Posts
