1 - 13 of 13 Posts
· Registered
Anything new on the market for filling/patching holes in exterior wood? I have used 1 part fillers and 2 part epoxy fillers in the past and am wondering if there are any new products worth recommending. The fixit spots require climbing a ladder so I'm looking for something that will last a relatively long time.
· Registered
dap33...
· Registered
Never tried that DAP product; looks promising...
I won't use any water based caulking on exterior wood. Urethane based caulking won't let go if the wood gets wet.
Having said that (I use that expression a lot) I do use DAP ALEX PLUS for filling nail holes and minor imperfections when I'm painting; dries fast.
I keep a squeeze tube in my pocket.
· Registered
I was lurking, hoping for more discussion here. So here goes:
If you're considering epoxy-based, I'm assuming you have big holes (say, bigger than a 1/2" diameter) and/or rot. This site looks like it has a pretty good summary of what's available:
The 7 Best Products to Patch Wood
Wood Filler & Epoxy Test (Year 3) - The Craftsman Blog
I wish he would have put a finish on his long-term test. Anyway, I've used the Liquid Wood & Wood Epox system on rotted wood in 4x12" Doug Fir beams, about a year ago. The rot was a gouge about 2' long, and max 2" wide, max 2" deep. It's holding up very well, but the stuff is pricey. Lots of great videos out there on how to use it.
For smaller fixes (I have some "alligator" wood I need to patch), I may try MH Ready Patch or Minwax HP Wood Filler.
· Registered
Discussion Starter · #9 ·
Good info. Thank You for posting.
· Registered
I have used this to patch a damaged door jamb and was very pleased with the results. It sets up very quickly so use small patches and use different mixing tools for each batch or you get cross-contamination and it sets up quicker - I use popsicle sticks and the lids off coffee cans, both can be used multiple times as the dried filler just pops off the lids.
https://www.amazon.com/gp/product/B0007ZG9T4/ref=oh_aui_detailpage_o00_s01?ie=UTF8&psc=1
I have looked at this product when I had a large area to fill - more skimming on a coat than anything else, but haven't had the chance to use it yet.
https://www.amazon.com/3M-Bondo-Solutions-Purpose-1-Quart/dp/B0007ZHTTS/ref=pd_sim_60_4?_encoding=UTF8&pd_rd_i=B0007ZHTTS&pd_rd_r=2C3EJ3DVQN8M1YNHB6CE&pd_rd_w=tGsqp&pd_rd_wg=JHmU6&psc=1&refRID=2C3EJ3DVQN8M1YNHB6CE
I'll agree with Stick and others, the DAP glazing compound is good for quick patching of nail holes and small cracks while you're cleaning up getting ready to paint.
· Registered
· Registered
Another filler I use, Elmer's Probond, interior/exterior
https://www.amazon.com/dp/B0149ISTCY/ref=asc_df_B0149ISTCY5157356/?tag=hyprod-20&creative=395009&creativeASIN=B0149ISTCY&linkCode=df0&hvadid=194013412954&hvpos=1o4&hvnetw=g&hvrand=13186354262106012813&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9007848&hvtargid=pla-312399739821
It fills nicely, minimal shrinkage on larger/deeper holes and doesn't seem to clog sandpaper as much as some other fillers. Don't know about stainable as it's a gray color sitting in the container.
1 - 13 of 13 Posts
