Face Lift for the Router Fence
This is just a new way to setup a router fence, it's copy cat in a way of
Bob & Rick's and Marc Sommerfeld router table and Fence http://www.sommerfeldtools.com/
Bob and Rick have used this trick for a long time now I see others doing it the same way.
You pin one end of the fence and swing (Pivot) the other end into the bit and cut a pocket for the bit to make a chip breaker and to hide the black hole behind the fence and to help the vac. do it's job .
Marc S. new router table is about the same thing, lock one end and swing it into the fence, cut the pocket and then lock it down with a knob on the fence.
The jig (face lift ) is about the same but I have used the T & G on the center part, so you can make as many as you want and use the top and the bottom of the T & G blank.
Marc's fence and Bob & Ricks is poly. and this one is MDF because it's flat and true and CHEAP...
Marc's fence has it set up with a 10 deg.cuts on the center part that's quick and easy to replace just like this one but this one is a T & G to lock it into the fence and I try to use the router when every I can to make jigs for the router table.
Note***if you got lucky and got the free video,you will see Marc S. use his new fence and router table.
Links b/4 the face lift and snapshots after the face lift below, plus some other jigs I use.
http://www.routerforums.com/showthread.php?t=2656
http://www.routerforums.com/attachment.php?attachmentid=2282
http://www.routerforums.com/attachment.php?attachmentid=2281
http://www.routerforums.com/attachment.php?attachmentid=2279
If you need more info just ask
Bj
Bj
