Hi TT
Well I was holding back to see if any one of the members would jump on this one.
I guess not, so I will give it a go.
You can do a search using the search tool on the forum and you will see many of them but no plans that I know about...
The fence is a important item to the router table and must be the right one for your router table, that said, I would make your own you can use many type of materials but I recommend 3/4" thick MDF stock because it's inexpensive unlike most of the other materials you will see them made out of and it's flat and smooth and knot free
I do recommend the pin and swing type fence, one end of the fence has a pin/bolt and the other end can swing away from the router bit.
Also it should be the split type fence that's to say the front of the fence can be slide open to expose the bit.
You can make one like the router boys use ( Bob & Rick ) but you will need to replace it all the time or make many of them.
As far as jigs they will come as you use the router table more and more.
I will post some of the types if you want me to, just ask and it's done.
Bj
