Hi
Do any members own this trimmer router. If so, may I have your advice on the correct ballbearing to buy for the cutter . There seems to be two different types, one with a thicher outside wall than the other which are available at bearing shops. Also, may I have advice on the two different dust shrouds produced for this machine. What is your experience with the cutter ball bearing brake, that spring loaded white plastic rod in the revised dust shroud?
