Around the holidays I bought my first router lift. It replaced a Rousseau plate I had used in a table saw extension with my DEWALT DW 625 since the 90s. Here is the new setup.
The Rousseau and Woodpecker plates are different sizes. Fortunately the Woodpecker lift is larger in at least one dimension. I was able to enlarge the hole to fit, drop it in and get to work.
I made my own router plate template by first using the lift plate itself as a template. I then tested the template in scrap to make sure it worked well, then used it in enlarge the hole in my existing table saw extension, and soon I use it again to make the opening in a new and larger extension.
After some initial headaches with the lift that required weeks to work through with the manufacturer, I am now one happy router (camper). The result is now a lift that works as sweet as one could hope. And boy is it fast and accurate. I expect this to last until I can no longer work with wood.
If any of you PRL V2 lift owners have issues with your calibration ring not rotating accurately as you turn the fine-adjust thumb wheel, let me know. I may have a simple fix for you.
Sent from my iPad using Tapatalk
