Finally Got It Done
3583 Views 29 Replies 22 Participants Last post by  hawkeye10
Rifle case for my brother.
Ebonized Walnut, Maple and Mesquite.
Hardwood Wood stain Wood Varnish Laminate flooring
Box Hair iron Metal
1 - 20 of 30 Posts
Beautiful job Gene. How did you ebonize the walnut?
OMG, you sure did,Gene, and in a beautiful fashion too,I might add. Is the dark the mesquite? I didn't know that they grew that straight for that length. You really out did yourself on that one. Thanks for posting, I have been waiting for a picture of that. Is that the first of many?
Reactions: 2
Thanks, Chuck. The black was achieved with India Ink. Tried the steel wool in vinegar method but, although it darkened the walnut nicely, it didn't stay dark. I found that, without applying a uv blocking finish, it's not light fast.
Thanks, Herb. The black is walnut. The browns are mesquite. It does grow straight, depending on the area. But, not really tall. Finding a useable log to yield more than 10-12' is rare. In AZ most are around 12-16" in dia. at the base. Some are much bigger but, also rare.
This is one of the nicest rifle cases I've seen & I used to work in a sports store that sold firearms etc. (before I became a Meat Inspector) Thanks for the ebonising info Gene,a lot of members will appreciate that. James.
Outstanding work Gene . Sure loving the different colours of wood . You’ve got a real talent there
That's simply a work of art! Very well executed.
James, thanks my friend.
Rick, gracias buddy. It ain't talent, its perseverance.
Mike, appreciate your kind words.
Andy, I'm blushing.
Absolutely beautiful! I like your avatar (I have one, waiting for me to learn what I’m doing). Kudos.
I just want to reach out and touch it, Gene! Beautiful.
Thanks, Dan. White gloves only.:wink:
Well done Gene....very well done!
A fine case worthy of any firearm
Reactions: 3
Better than nice !!!!
How many ways can you say outstanding? Beautiful.
Yea I can't come up with anything, simply don't have the vocabulary. It is absolutely beautiful. Care to share the build? Mitered corners with splines? What did you use for the interior? Foam? Finish? etc... For me, it is a rare occurrence, that a box will put a beautiful gun to shame. You managed to do it!
That's nice. What is the padding in it?
Thanks guys. You all are incredibly generous with your praise. But, keep it up. I love it.
Bob, the corners are lapped. The splines are DTs.
And Theo, the rifle is French fit using Kaizen foam. Its sold by Fast Cap for tool drawer organizers. An object is laid on the foam and it's outline is traced. Then it's cut out only as deep as you want it. Kaizen is made in thin layers so, when you cut the outline you can reach in and pull the layers out. In the case of the rifle, deeper for the stock and shallower for the barrel, etc.
Again, thanks for the very nice comments. They mean a lot.
Reactions: 2
Beautiful job Gene, that looks great!
Superbly done.
1 - 20 of 30 Posts
