Fine particle dust collector for shop
4511 Views 14 Replies 10 Participants Last post by  Murtu01
For the shop I made up a water filter out of a 5 gal. bucket and a vac that fits on top of bucket. I found the idea on you tube, But the foam builds up in the bucket & goes through the motor what can be done to keep foam down. I'm going to eliminate the bucket motor & try hooking up to a regular vac. household type put another baffel on top of the collection bucket see if that helps
If anyone out in router world have any thoughts to help I will listen
THANK YOU Stephen
1 - 15 of 15 Posts
welcome aboard.....
A cheap box fan with an AC filter attached to the front will help a lot.
Hello Stephen, glad you found us, it's great to have you as a member of the community, welcome to Router Forums.
Welcome to the forum Stephen.
Hello Stephen, welcome to the forum.
Could you use a deeper bucket?
Vax sell a defoamer liquid for their Vax wet n dry vacuums because when used as a carpet cleaner, the cleaning liquid causes excess foam in the bucket. This reduces the maximum content as the foam makes the little ping-pong ball rise up faster until it blocks the suction.
Not sure if it would work in your situation but does defoam soapy water.
Stephen, I second Mike. I use a box (window) fan with a furnace filter in my 13' x 19' shop. I found that if I keep the door closed that the fan re circulates the air in kinda a vortex and clears the room of airborne particles in only minutes and even faster if left on all the time. the filter is on the intake side of the fan and I face the exhaust side against the wall. As far as your wet filter idea I have one thought...MOLD!
Here's a link to a Forum thread that a pile of information http://www.routerforums.com/shop-safety/21825-index-dust-collection-solutions-comments.html and Kevin Brady had good information plus a good design or 2 on some shop made filtration
Kevin Brady - DIY Dust Control Devices .... Basically a filter on the intake of a box fan but on steroids.
Hi Stephen, I would like to see some images of your DIY water filter.
Rudi
Reply to filter fan
:big_boss:I'm gonna get a filter today thats a great idea, But on the wet dry filter thats mainly for interior dry wall work. As you can imagine thats gotta be some of the finest dust in this world. The problem w/ the foam is the dust is inside the bubbles & goes out the exhaust as dust
I've thought about that< I'm using a bucket motor a wet dry set up for a bucket, deeper bucket yea might help but the foam is abundant Maybe I'll put a lid on existing bucket & move wet dry motor to another bucket hen connect w/ hose I think that would make for a deeper bucket?? I found out through this forum they make defoamers for carpet cleaner wet dry ?? try that. One more thing this is for drywall dust gotta be the most finest dust in the world Thanks Stephen
I'm gonna give it a shot,cause I didn't mention that this is for drywall dust & the cost of filters 4 wet dry are 7.00 each
Reply to water-filter
Helloot Rudi, this is the water-filter I made up from a plan I got off You Tube, I finally solved my foaming problem by jumping over a 2nd bucket kind of like 1 guy said larger bucket acts as the same call the filter bucket as shown in pics. as 2ndary bucket, the primary bucket mounts the bucket motor connected w/ a hose solved the problem of the foam entering the motor. Oh yea I almost forgot to mention that this operation is for drywall finishing @ occupied residence. Drywall dust has got to be the most finest dust on earth,finer than moon dust,OH YEA thats not of this earth LOL
Thank you Stephen
Rudi
Thanks a mil, simple and design and not too difficult to make - this really helps a lot.
Regards
Rudi
1 - 15 of 15 Posts
