1 - 8 of 8 Posts
Administrator
David - Machinist in wood
A friend asked if I could make a finger labyrinth for his son. I grabbed a photo off the Internet, did some modifications, and cut this out of Maple for him. It's about 11.5" diameter and finished in Nitrocellulose lacquer.
Plate Circle Dishware Wood Tableware
Wood Plywood Carving woodworking Pattern
David
Administrator
Discussion Starter · #6 ·
Thats pretty cool! What machine did you run that on?
Thank you! This one - 2nd Build (first)
It took an hour to get the drawing right, 10 minutes to prep the wood, and 4 minutes to cut on the CNC. Then another 10 minutes of sanding followed by spraying a coat of sealer on both sides, sanded again, then a finish coat of gloss lacquer for a total finishing time of an hour or so.
So the least amount of time for this was the CNC but it was also the most significant and noticeable part of the job. :grin:
David
1 - 8 of 8 Posts
