finish to use over water based stain?
14K views 10 replies 4 participants last post by  jerrymayfield
Are there any limitations on the type of finish I can use over wood I've stained using a water based stain?
rstermer
Thanks Jerry, Once I apply the shellac can I then apply my finish over the shellac? Excuse me for being obtuse, but finishing is the area of woodworking about hich I know the least and which gives me the most problems.
rstermer
Shellac naturally contains wax(this is the type I use most of the time). The ever present polyurethane varnish and now water borne finishes have trouble adhering to natural shellac, so the caveat about dewaxed.Since it has been a while since you have used shellac, try to forget all about applying varnish. Shellac is a different animal. It is an excellent finish, I really like the less refined grades. Good luck, I think you will like it.
Regards
Jerry
What are you finishing and what look are you going for?. In many cases shellac doesn't need to be top coated. Finishing is a skill that is learned like others,the only mystery is the little facts the finishing companies are willing to share and the misinformation that is given out as facts by well intentioned people.
Regards
Jerry
I have made a replacement top for a jewelry box and am trying to match the existing finish which is a dark red mahogony often seen on wood items imported from China. It looks like I won't need to use the water based stain as it was too brown in tone when I applied it to a test piece of the poplar I used to make the replacement top. Right now I have a coat of red mahogony on as a base. I'm going to add a second coat of the red mahogony and then finish with two coats of Bombay mahogony finish, which is a combined stain and Polyurethane finish. That combo seemed to match the existing finish on the rest of the box pretty well. Its not a finish I would select myself if I was starting from scratch, but I need to match what is already there.
rstermer
Thanks, I'm really new to woodworking and not very skilled, so it takes me a long time to do anything. I really hate it when I screw up because I've got so much time invested in the work, but I think this will be ok. I already tried out the combo on some scrap and it seems to match the existing color pretty well.
For future reference I'd like to learn more about the dye stains you mentioned. Do you have any links or other info sources you could point me toward?
Thanks,
rstermer
