1 - 15 of 15 Posts
Discussion Starter #1
I case you missed the announcement, the KIDDE Fire extinguisher Company has announced a voluntary recall of their fire extinguishers equipped with "plastic" handles. Check out the following web site for details.
https://www.cpsc.gov/
If your extinguisher(s) are in the faulty category they will be replaced at no charge.
And if you don't have one in the shop and/or house and garage, I recommend adding one or more.
That's a lot of fire extinguishers to recall!
The plastic nozzle/handle extinguishers were always a problem. I recall responding to a call where a plastic handle Kidde extinguisher mounted on the wall blew the nozzle mechanism right out of the extinguisher body. The nozzle/handle mechanism had penetrated the sheet rock above the extinguisher. 2 1/2 lbs of extinguishing agent makes a VERY large mess. The home owners were not impressed.
Premium Member
I don't ahve an extinguisher in my shop and office. I think I'll get a couple of the larger ones. Sounds like a good idea. I know you have to have them recharged occasionally, but they have a dial indicator that tells you when. I'll look for a metal nozzle and handle. I think a steel box to hold volatile liquids is also a good safety measure that hopefully you'll never need.
I saw that on Fox News last night. I agree that is a lot of fire extinguishers.
Premium Member
I bought one last year and will have to check . If I can find it :|
Premium Member
Talking of extinguishers, When I was serving my two years in the RAF one of the lads emptied the contents of one of the extinguishers, the type filled with Carbon Tetrachloride, and filled it with petrol to light the barracks stove!!!! I survived.
Reactions: TenGees
I checked my fire extinguisher-outer and it is another brand. Metal valve and stamped metal handle and trigger so I'm OK but thanks for the notice.
One thing that everyone should be aware of, the powder in these extinguishers is highly corrosive over time if it is not properly cleaned up. Back in the days of VCR's, if you had a small fire in one room and used dry chemical extinguisher. People were finding there VCR heads were pitted so bad the VCR was no good. I had a friend that had an electrical fire under the dash of his car. He used a very small spurt from a dry chemical extinguisher. After the repair and cleaning up as much of the dry chemical that was possible. With in a few months he started having computer and electrical problems with his car. After doing some investigation he found that a bunch of connectors had corroded pins on both end of the connectors. This was all caused by using dry chemical extinguishers.
I either use foam extinguishes or CO2 extinguishes, both are very hard to find and expensive also another alternative is a Halotron extinguisher also expensive. I have 2 Kidde foam extinguishers, Kidde no longer sells these extinguishers to consumers they are only available to commercial users.
CAD-Man
@Desertrat
" I know you have to have them recharged occasionally" !!!!!
Good luck with that-- I tried recently to get some recharged with no joy.
NO professional company would do it to plastic handle units
& it was cost prohibited to recharge metal handle ones.
Checked with the local fire department & nobody does it. Used to be that firemen did it as a side job--no more---to much equipment is involved. So they say.
Then it became an issue to properly dispose of old units that were still showing a charge.-Don't throw them into the garbage truck. When crushed they can explode.
So I tried the town.The town clerks drew a blank--- had to get the county involved to lean on the town to take them .
so again --good luck
They can be easy to dispose of. Tip the extinguisher upside down, pull the handle, discharge all the propellant. When the pressure is gone, it is no longer a pressure vessel and is safe to toss. The plastic nozzle unscrews and you can even recycle the metal. Or discharge the contents into a garbage can (wear breathing protection and do this outside!) It's always good to think of the waste management folks when disposing of potential hazardous materials! When I taught a lot of fire extinguisher classes for businesses, they would use their outdated extinguishers to do live fire training, which is a great way to use up the extinguisher before it needs to go in for it's 6 year/12 year service. A lot of businesses have an OSHA requirement for fire extinguisher training, and there's nothing better than pulling the pin and extinguishing a real fire!
Fire extinguishers used in a commercial application/business have to be discharged every 6 years and checked/refilled/resealed. After 12 years, the extinguisher has to be hydro-tested. That only makes sense if the extinguisher was a good one in the first place. Here, it's about $15 bucks to refill a 5 lb extinguisher. That same extinguisher new costs between $50-75 bucks, so it makes sense to get them serviced after use.
CO2 extinguishers have to be hydro-tested every 5 years for steel bottles (same as SCBA) as the bottles are rated to about 1800 psi.
My fire dept. used to refill extinguishers for the public many years ago, but because of the liability and the change in rules that requires much more extensive testing of the extinguisher, we quit doing it. The equipment isn't cheap, that's for sure! Plus, our department did not want to be considered to be in competition with a private business that was trying to make a living.
Extinguisher places won't take the plastic nozzle ones after discharge because there's almost a 100% chance the extinguisher won't seal after it's refilled. They really are junk.
Our Navy sailors were notorious for using extinguishers for cooling beer really fast ( until the CO stepped in and spoiled the fun)
Thanks for the notice... I have extinguishers on every floor of the house and one in the shop as well... Good news is that I am unaffected. Some of my units are over 20years old. I wonder how long a shelf life these things have... OK needs some research :)
1 - 15 of 15 Posts
