I had this idea for a very long time and wondered why I had never seen another like this. Now I know. This is not an easy pattern and I'm still trying to make it better/ fit better/ look better. The cutting boards.....made more than one....are Maple and Padauk with the Padauk inset, some inlaid on both sides, some one side. Cutting boards are 18" X 9" X 1/2" thick. I have done four inlays with a 1/4" straight bit, using two different size guides. I have done one board using Milescraft inlay set up, and one board using a Whiteside inlay guide bushing and collar with 1/8" down-turn spiral bit. I find it the same amount of work to fit the insert with all three methods. I am convinced that percerverance and stiff socks are the only method that works.
The boards are finished with foodsafe butcherblock coating. All were given as gifts and I have 5 more on the go. They will be ready when I get the inserts to fit correctly, with very little sanding after cutting. Any helping suggestions are appreciated.
