Flattening a stump
15K views 42 replies 15 participants last post by  Herb Stoops
Hello all,
Anyone have any luck flattening a stump?
Stump is about 3 to 4 ft in diameter.
Thinking boxing it out with joined top 2x6's screwed to the sides, with a sled on top to remove material.
Thoughts?
Thanks, Tripp
some reason you can not or do want to remove the stump completely for around 100.00 and be done with it.
#16 ·
Yes, I see no reason why this wouldn't work to level the surface. Make sure your frame is solid and won't move on you... maybe go so far as to sinking it into the ground to help with stability, and take little bites at a time until you get it where you want it.
Old stump in most climates attract termites, which soon discover your house. We kept a near 4 ft stump and within a year it was infested, and that's in a very dry region. Then had it ground down, which we do with all removed trees now.
#22 ·
I made a lot of burl tables, back in the day. Ninety-nine percent of my work was free hand using what ever gnawed off wood.
For example, I used a chain saw to rough it down, then an electric hand plane. I have a Porter Cable Siding Sander and a twenty-four grit, carbide disk for it, so using that, then a belt and ROS was fair game too.
When I was done, I had a piece of tempered glass cut for the top. To support it, I used car valves. I just drilled holes and, using a level, pounded them down, until they were all level with each other.
To disguise the use of car valves, I just took some PVC and cut it to the same length as from the underside of the valve to the wood. Then I used a round rasp to put a bevel inside the pipe.
When done, I cut into the pipe with a band saw, so the pipe would spread to drop down over the valve and snap shut when against the wood.
No one ever knew.
#23 ·
ew.. those are nice...
Reactions: creative
#24 ·
Just a thought......I have never routed green wood before. If the stump is fresh cut ,how would green wood cut with a router? End grain too? Also if it were a Doug Fir,Pine,Larch, or such large stump , the pitch would be a problem would it not?
I had several large Fir trees cut years ago ,and like Tom said the carpenter ants and red termites moved in a couple of years later. When they were cut, the pitch just poured out of the stump.
#30 ·
Sir Herb. The pitch that comes out of D. firs is usually caused by a shake in the tree. I think that Chuck could explain this better than I, but essentially, when a big fir - or medium sized one I guess - goes through a big windstorm, it bends.
Now sometimes, adjoining rings inside the tree will separate just a little. Over time, this shake area will start to fill with pitch. When the tree is cut down, that pitch has nowhere to go but out.
Something else to look for when a fir starts to lean a little is pitch coming out one side of the tree higher up. This may be caused by either damage to the bark, e.g. a branch snapping off right against the tree, or a shake close to the outside of the tree. This usually shows up as a yellowish looking substance which will run way down the tree, or if the tree is over far enough, it will simply drip onto the ground. It's all but impossible to clean this stuff off if it gets anywhere on you.
#25 ·
I did this one a bit over a year ago, transit and chainsaw and wifey. However a stick banged into the ground with another screwed into it with a cheapo centering bubble on the cross stick and a helper would provide the same result.
What I did discover, due to my lack of lumberjack skills is the top doesn't need to be perfect flat or level, it can be shimmed to perfect. What is important is the diameter of the table in relation to the diameter of the stump and what the tables function will be.
Big diam. table, small diam. stump
Supporting flower pots only, an equilibrium can be acquired by even distribution of weight.
Table used for entertainment, food, etc.
If it will require bracing.
I cut the stump to its height during the winter after a big honkin snow storm snapped that trunk. Lucky only one of the large branches from it hit the corner of the house leaving -0- damage. You may consider treating the stump top with fungicide and insecticide to prevent rot and infestation.
#37 ·
By far in my area, residential/commercial properties suffer from carpenter ants than termites.
Regarding trees, the big problem in our area are tree borers, they seem to go after live and healthy as well as aged and deteriorated. The white pine in my previous post was saved from pine bark borers about 20 yrs ago by the whole family and insulation retaining rods, my wife, kids and I would go out to the pines in the yard, wherever we found a hole in the bark, weeping or not we poked the rods into the holes to destroy the bastiches.
The woods behind our house look like a war zone with all the dead WP, but it's just as bad out front now with the pitch pine borers, a tree falls about once a month, unless its really windy. So many dead trees and all I've heard from the town and extension service is we don't know and we're looking into it.
Ants and termites will tunnel wherever the wood is rotting, I've seen mud tunnels running from grade up foundations on a few homes and condos.
#43 ·
I think it is already being used for that, Tom.
Tamarisk? that is a new one one me. Wonder how they got started here.
Wonder if some creative landscaper planted them thinking they would survive in arid climate?
All of my blue spruce were killed a few years ago by some bug. At one time they were thriving and beautiful, then the needles all fell off and they were done.
#41 ·
When I built our sheds, I found a root about 7 inches across had grown all the way to the front yard and helped damage the septic system. In their search for water, the can and will grow beneath your slab and break it up. Root system is expansive and shallow. Best thing to do with a Cottonwood is have it removed.
Out here in the desert, we also have an invader from China, the Tamarisk. Its tap root will dive a couple hundred feet for water and it sucks up about 200 gallons of water a day and on top of that, it adds huge amounts of salt to the soil around it so nothing will grow there.
We just had to remove a number of trees recently, two Tamarisk, a beautiful pine that had become a fire bridge to the house, and a little ash tree that was nearly dead anyhow. Have some new small trees to plant, but they won't be producing any shade during my lifetime.
