Just one more Update
Well I did two boxes as a test, in Kelley Green Suede Flock see below,,, we all know how hard it can be to get the box to look good inside
this is a easy way to get that done and it's quick just put on the paint/glue from the can and with in 15mins. or so put the flock on with the tube that comes with the kit (looks like a shipping tube with 5ea. 1/8" holes in one end) but it works well for this job
looks like I will make a stop by the office supply to pickup some more tubes.
I also took some other snapshots because I was taking some of the box and the flock job all in all it's a great way to do the inside of many items.
Thanks to del for the link for the flock kits, it took about 4 days to get it by UPS.
Just one users review ▼
I do recommend this product from ▼
,it's a easy one to do, little masking tape and some poly.spay to seal the box inside and the kit and you will have it done in no time, the hard part is waiting for it to dry so you play with it.
( I did it late at night so I could play with it the next day ) hope this helps someone that wants to flock a box or two
NOTE*** besure to seal the inside the box with some type of sealer, this will keep the glue/paint from soaking into the wood and will help in drying time as well, if you don't seal it the color will be off or to say blotches.
Once it's dry ( 15 hours of drying time) just blow it out with the air hose but with care you don't want to blow out what you just put in place, it takes 72 hours b/4 it's cured,you can take a soft brush and with care clean the box and out and reuse the over blow, if you want then just blow out the box and your done...
http://donjer.com/shopsite_sc/store/html/index.html
http://donjer.com/shopsite_sc/store/html/page1.html
http://donjer.com/shopsite_sc/store/html/page2.html
Bj
