It would help if you described what you are using it for also what kind of wood will you be drilling, and on a drill press or hand drill, and what diameter is the hole.
I use Forstner type bits all the time ,but not any like that one. Most of mine are chinese,but do have some better ones. I use mine mostly on a drill press .
On very large holes I use a hole saw ,it is easier on the drill and easier for me to not tear up the back side where it exits.
The one you show is more what I would think of for plumbing or electrical wiring holes , these are more for rough work is my guess. I use the ones that have teeth around the perimeter, not the wing cutters you show. More like These:
HSS Forstner & Saw Tooth Bits - Lee Valley Tools
