Afternoon everyone! I have a question that maybe a seasoned pro could help a novice wood worker with. I am using a 1-1/4" forstner bit to bore an 11/16 inch hole into 3/4 inch thick pine leaving only 1/16" of material. When I do this, the thin wood that is left has a circular impression in the form of a 1-1/4" circle on the un-bored side that I am finishing. When I look at the hole I can see where one of the outside cutting teeth is going deeper by about 1/32". To bore this hole, I actually use 2 different bits. The first bit is the starting bit that has the centering point tip on the end. I go about 1/2 inch deep with this one and then I use a 1-1/4" finishing forstner bit that I grinded the centering tip off of as so it does not punch through the wood. I have verified that the table is perfectly level along the X & Y planes. I don't know why this is happening. Any help would be appreciated. Thanks in advance.
-Fred
-Fred
