Freud 3.25 hp router
6.8K views 18 replies 7 participants last post by  GeneSimm7
I noticed that Woodcraft has a sale on the Freud 3.25 hp router for 199.99. Has anyone had experience with this router? It seems like a pretty good deal.
Thanks KR
Kelly, this is a popular router. Members who own it like everything but the switch lock.
That uses the same switch configuration as the 1700's and, while a bit different, is very easy to use and especially shut off. Spring loaded release shuts it down. Triton T-4 uses the same configuration. Does take a bit of getting used to though.
Hi KR
I called also, you can pay for it on line and they will ship it on 27th of Nov. (BF deal) from the warehouse, as long as supplies last..the early bird gets the worm thing :)
#13 ·
:yes4:This is a very informative, and intertesting read.
I've been looking at plunge routers on E-Bay and CL for about the last 6 mos now, and haven't really found any deals, new or used, but this, wow!
As background info, I have an old Sears 1HP fixed router that I've used forever and still works; another newer 2HP variable speed but only 1/4" collet, and the Milwaukee 5625-20 that will probably end up in a table some day. I wanted to pick up a plunge router for making signs and working with templates etc. I know this is overkill, but it would be nearly the same pricewise as a smaller 2HP router. I know it's heavy, but I have pretty big mits, and think I could handle it OK. And I wouldn't be using it all day, every day. I've called my local Woodcraft store, and if I prepay, they'll hold one for me at that price, and I can pick it up after Black Friday. Any comments?
Hi Frank - I'm not real sure but from the picture it looks like the baseplate will take the Freud FT 1100 PC bushing adapter. Could call or e-mail Freud customer service to make sure. I've found them to be very helpful.:)
#16 ·
Hi Frank
John is right On, but by using the Milescraft base plate it will make it easy to change out the brass guides but if you use the brass adapter you can drill it out to take on the bigger brass guides that's a real plus for the brass adapter..
