tell us about yur table....
in detail...
in detail...
Table?tell us about yur table....
in detail...
you to adsorb this information..Table?
Ok. just a typical cheapo "sears" table top, 925479 with short legs and a fence. While I was getting the number and some pictures, on a wild hare came up to me and whispered "try slowing it down some more". Dummy bunny. It got worse. So, being a bright feller, I sped it up, bit by bit, so to speak, and it smoothed out perfectly. It now inspires a wee bit of confidence. And certainly cuts easier.
No idea if it is some "sweet spot" for the bit, the router, or the combination. But, it is what it is.
I suspect the table...I wouldn't expect an out of balance bit to settle down at any speed. Is this the only bit it vibrates with? And are you clamping the table down onto the table or stand it's sitting on?
Brand new collet. Had never used the 1/2 inch and thought I had lost it when first thinking about the type of bit to use. Still in the bag.A point about any large cutter of any sort. If your collet is worn at all, that can cause vibration in your cutters. I have found by turning the bit in the collet 180 degrees can help.
Removed router from stand and it acts pretty much the same. Put in the groove bit and it runs smooth as silk through out the speed range. BTW the mounting screws are flat head machine screws with a hex head. Not sure where I got them.Indoor heating season here. It is a conditioned space but some variation must be expected. When I got the biscuit idea, did not think about the variation, so they would likely be visible at times. That is one of the reasons tongue and groove seemed like the way to go.
The spline idea is more attractive now, as just making groove cuts seems easier.
But I think it is all stop, so to speak, and get at the cause of the vibration before going any further.
