If you want to find a centering bushing for the larger hole set up then you might want to check out oak-park. I got one of them for my larger guide bushings and for when I build my own mounting plates. If you are on the mailing list from router workshop they let you know when the sales are... always make it a better deal.presumed_druid said:As Ed mentions, lee valley uses 1 and 3/4 inch inserts. They also sell a universal base plate (you drill your own mounting holes in it) that accepts the inserts/guides. I just ordered one up, along with the insert and guide sets. The base plate is 9" diameter and can be used both free hand, and in table. It looks promising.
Thanks for the information.krams said:OK here are a couple(=2?) questions:
1) What is the dimension from the chuck/collet to the exposed side of the sub base with the router set to maximize this distance?
Will this be the radius of the sub-base plate?
What I'm looking for is the "travel" of the router, from its highest point to where the chuck is just level with the bottom of the sub base.
2)If the router were mounted in a table and if you were working from above the table how many "turns" does it take to have the chuck/collet to the point where you can change bits?
The fine screw turns 1/64thand it takes a few turns. I can measure exactly and let you know tomorrow or so.
Let's change the questions to: how far does a full rotation of the fine screw move the router bit height?
3) Is there a "quick release" that allow the router to be moved from a operational height to a bit changing height or from a bit changing height to an approximate working height?
Yeah, rather than turning the fine screw, I just use the quick release to push the motor up so the collet is exposed. This quick release basically releases the screw drive and allows the motor to be freely pushed up and down.
4) Is the above the table adjustment tool have a course and fine adjustment?
Nope. The drive above the table is just llike the one below. 1/64ths.
5) How is the shaft lock done and undone?
When the motor is pushed up to the point where the collet is visible above the table there is a rod that pushes into the collet's neck(?) which has a hole to accept the rod. The collet needsto be spun a max of half a turn before the rod engages the shaft and holds it.
6) Do they tell you what the dB number is for the router at full speed?
I have to look athe sheets that came with the router. I 'll get back on this.
7) Is the chuck/collet self releasing?
After you turn the collet with the wrench, it loosens and can be turned with the finger for a turn or two and then tightens again. Then it can only be turned agan with the wrenh and the bit needs to be pulled out but comes off easily - Is this self releasing?
No that is not self releasing.....
8) Will standard pc template guides fit?
No idea still. Looking for some help on this one.
9) What is the wrench size for the collet/chuck?
There is a number 22 on the wrench. Not sure what it means.
My guess is that it is a 22mm.
Actually, Ed, the Lee valley base plate comes with a centering system. Thanks though!reible said:If you want to find a centering bushing for the larger hole set up then you might want to check out oak-park. I got one of them for my larger guide bushings and for when I build my own mounting plates. If you are on the mailing list from router workshop they let you know when the sales are... always make it a better deal.
Ed
I just have this thing about those type chucks/collets, I'm sure a lot of people don't mind that design and with the great feature set most people will enjoy theirs.krams said:I have had this for only a week now. I wanted to get some real opnions on what I have got ...being my first router, I have to learn wht to look for and learn. which is why I am here.
thanks
Krams
Gee I should have know that leevalley would take care of that... I like that design and I might own one some day (I have to start parting with some router tables and get to a reasonable level... I have 8 right now).presumed_druid said:Actually, Ed, the Lee valley base plate comes with a centering system. Thanks though!
The collet moves 7 full turns of the fine screw ( 7 * 1/64 ) form the bottom to the top just below the point where the shaft locks up.reible said:Thanks for the information.
I like all the answers except for #7. I have a couple of router with that type chuck/collet and that is one thing I made sure I didn't get again. I don't want to sound negative and I sure don't want to rain on your new purchase but that is a deal breaker for me.
Please keep us posted as to what you find out about the guide bushing and other details or issues you find, I'm sure a lot of us are interested.
Ed
I just got the FT 1700 and the collet is self-releasing (unscrew the collet nut all the way, and the nut and collet come off as a unit).reible said:Thanks for the information.
