You're Welcome Michael
Well I talked myself into one also, hahahahahaha
I didn't want to mis the great price...
Just a note** "I have limited space"
I made a router setup for a mate that had the same (limited space in the basement work shop) I set it up like the old time iron table, that dropped out of a box on the wall,it took up about 8" of the wall and about 28" x 30" box with the fence.
I don't have snapshots but it was a easy one to make just the router table top and two drop & lock legs.
He used the OakPark base plate and puts the router under the work bench with the base plate when he is not using it.
Thank You for ordering from Sommerfeld's Tools for Wood.
Your order has been received for processing.
SommerfeldTools.com Order Received
(QTY: 1) CAT: Sommerfeld's Catalog ($0.00) $0.00
(QTY: 1) 999.501.09: CLOSE OUT SPECIAL - Industrio Phenolic Routertop WITH insert ($99.00) $99.00
(QTY: 1) GLAS/RTBRN: Rubber Glass Panel Retainers, 25' roll ($14.99) $14.99
(QTY: 2) 991.001.00: Bent Wrench for Porter•Cable ($14.95) $29.90
(QTY: 1) 999.501.04: Zero Clearance Inserts (3) ($19.95) $19.95
(QTY: 1) VIDFREE.003: FREE: Router Tables Made Easy (VHS) ($0.00) $0.00
Shipping: $29.94
Total: $193.78
Bj
