couldn't find any on their site, however for some sets, you can use the Sommerfeld setup jig for Freud. Only covers a few specific bits, but it also accounts for workpiece thickness. $32 on Amazon
https://www.amazon.com/Sommerfelds-...=2025&creative=165953&creativeASIN=B00GEC2HCW
Here's the pitch on Amazon:
Product description
This Easy Set Jig sets Freud lockmiter bits and other Freud hard-to-set bits quickly and easily. Now, with the new Freud Easy Set you can position your router bit perfectly the first time, every time, in any thickness of wood - from 23/32" (3/4" plywood) to 1 3/16" thick stock. The eight Frued router bits that match the profiles on the Easy Set Jig include:
-45 degree lock miter(99-034),
-glass panel cope bit(99-286),
-raised panel bit(99-569),
-reversible glue joint(99-031),
-drawer lock bit (99-240),
-baby lock miter bit(99-035)
-22 1/2 degree lock miter bit(99-043), and the
-raised panel cope bit(99-260).
-Also any Freud raised panel cope cutter or raised panel bits can be set with the Easy Set Jig since only the tongue portion of the Jig's profile is used during the height-setting process.
Hope this is helpful. I use the Yellow jig for my Sommerfeld sets.
