Looks like a mechanical issue, like a slipping coupler or pulley.
Maybe Avid CNC has a good idea by keeping their VFD in a separate enclosure? Although it has been mentioned that they do it more because their main enclosure is to small.Great news! While checking all your solutions, I believe I found the problem. The spindle motor wires seemed to be affecting the axis stepper motors, so when separating these two components (and again, making sure all the screws are tightened), these two engraving came out perfectly.
Thank your all for your help~
The main issue is running spindle wires parallel to others (like in cable chains). Shielded cables and proper shield termination helps.Maybe Avid CNC has a good idea by keeping their VFD in a separate enclosure? Although it has been mentioned that they do it more because their main enclosure is to small.
