New out of the box Genmitsu Proverxl 4030. Jog controls don't work. Will not respond. Error code 15. "exceeds work area". Happened right after I gave it the home command. It returned to home then nothing.
** Connected to COM3 @ 115200 baud **
Grbl 1.1h ['$' for help]
$1 = 0 (Step idle delay, milliseconds)
$2 = 127 (Step pulse invert, mask)
$3 = 248 (Step direction invert, mask)
$4 = 1 (Invert step enable pin, boolean)
$5 = 0 (Invert limit pins, boolean)
$6 = 0 (Invert probe pin, boolean)
$10 = 250 (Status report options, mask)
$11 = 0.000 (Junction deviation, millimeters)
$12 = -0.000 (Arc tolerance, millimeters)
$13 = 0 (Report in inches, boolean)
$20 = 0 (Soft limits enable, boolean)
$21 = 1 (Hard limits enable, boolean)
$22 = 0 (Homing cycle enable, boolean)
$23 = 86 (Homing direction invert, mask)
$24 = -2147483.648 (Homing locate feed rate, mm/min)
$25 = 0.000 (Homing search seek rate, mm/min)
$26 = 2 (Homing switch debounce delay, milliseconds)
$27 = -2147483.648 (Homing switch pull-off distance, millimeters)
$30 = -2147483648 (Maximum spindle speed, RPM)
$31 = 0 (Minimum spindle speed, RPM)
$32 = 1 (Laser-mode enable, boolean)
$100 = 0.000 (X-axis travel resolution, step/mm)
$101 = 0.000 (Y-axis travel resolution, step/mm)
$102 = 0.000 (Z-axis travel resolution, step/mm)
$110 = 0.000 (X-axis maximum rate, mm/min)
$111 = 0.000 (Y-axis maximum rate, mm/min)
$112 = 0.000 (Z-axis maximum rate, mm/min)
$120 = -2147483.648 (X-axis acceleration, mm/sec^2)
$121 = 0.000 (Y-axis acceleration, mm/sec^2)
$122 = 0.000 (Z-axis acceleration, mm/sec^2)
$130 = 2147483.648 (X-axis maximum travel, millimeters)
$131 = -0.000 (Y-axis maximum travel, millimeters)
$132 = 0.000 (Z-axis maximum travel, millimeters)
ok
ok
ok
ok
Any help would be appreciated!
$0 = 112 (Step pulse time, microseconds)>> $$
ok
[GC:G0 G54 G17 G21 G90 G94 M5 M9 T0 F0 S0]>> $G
ok
ok
ok
