Status
Not open for further replies.
1 - 20 of 215 Posts
Administrator
Discussion Starter #1
Nice system. My shop is well insulated so it stays fairly cool most of the day in the summer and I have a radiant tube heater for winter so that would be a tough question as to whether I would put it in the shop or my house.
Reactions: Cricket
Sure Can Use This
How do you keep your workshop area cool in the summer and warm in the winter?
I work out of an uninsulated Florida garage. Heating is never a real issue, but cooling is! Generally, it's open doors and a big noisy fan for the cooling. Oh, and lots of water to drink.
Where will you use the Sharp Mini Split if you win?
Unlike somebody, here, I'd be insulating the garage.
What is really impressive is the 22 SER rating.
thanks for the offer but there is no need here for one...
In SW Missouri during the summer it gets pretty warm and I use fans and the exit method. It gets to warm I exit the shop. In winter I have a couple of electric heaters that keep it fairly warm. If it gets to cold I use the winter exit method. I go in the house. I would definitely install the unit in the shop.
Reactions: Cricket
In the summer, the garage is actually pretty cool in the morning as long as I don't open the bay doors too often. After 1300, it starts to get pretty hot. When that point is reached, both bay doors open and the circulating fan is run. At sundown, the doors have to be closed so the mosquitoes don't begin feasting on me, so a low speed fan is used.
In the winter, I have a propane heater that I use to get the shop up to temperature, then I shut it off and it's usually not that bad as long as I don't go in and out of the big doors.
I would love the mini split system to use for my wife's sitting/sewing/workout room that we added on a while back. The heating and cooling ducts for that room hang inside of my workshop, and lower the effective ceiling height a foot. Plus, it is hard to balance that room with the rest of the house, so she usually supplements with a space heater in the winter time. The ability to have that room on it's own thermostat will give me back my overhead clearance and probably put a dent on the power bill.
I have a window air conditioner, and a 220 volt electric heater....
Where will you use the Sharp mini split, if you win ??
In my well insulated stand-alone shop....
Well....in the summer i open both ends of the shop and turn on the fans, in the winter.....pretty much the same thing..lol...on cooler days I might light a propane heater.
This would be perfect in the office......gets a little toasty in there.
My shop is heated by the sun during the spring, summer and fall months. In the winter I have a propane heater but it doesn't do much.
If I were to win I would probably use it in my 3 Seasons room which I try to use year around.
Fans for cooling and propane heaters in the winter months. I would install the heater in my shop.
Reactions: Cricket
Radiant floor heat..
and it seldom gets much above 70° w/ really really low humidity..
berserk R levels of insulation..
Reactions: Cricket
Super Moderator
John
My shop is in the basement so I have it heat and air-conditioned.
If i was to get the SHARP 9000 I would install it in the garage because I have some larger equipment like panel saw and would like a larger CNC table
Reactions: Cricket
My workshop is so minuscule that in inclement weather, if a portable fan or space heater is insufficient, I must forgo the current project in favor of planing the next.
Reactions: Cricket
Super Moderator
David
Currently using a 12,000 BTU 22 SEER Gree mini-split for our attached and well insulated two-car garage in northwest Louisiana - hot, humid in the summer and colder than you would think in the winter.
I need a smaller shop out back for my guitar building and the Sharp mini-split would be perfect for that.
My shop in neither heated or cooled. I use window fans in the summer and a portable heater to preheat my shop in the winter.
I would use the Sharp Mini Split in my work shop to extend my "wookable day's".
A needed expansion
Since my shop is in my basement, it is conditioned by my home furnace/air. My shop is only 13'x19', and it would be nice to expand into my un-heated garage to gain shop space. I have not done so due to not being able to control the humidity to prevent rust. The heat pump sounds like a great solution for year around use and could be quite economical to run. I would use this in my garage.
My shop/garage has no adequate climate control. It is heated in the summer and cooled in the winter largely by the local temperatures. Temperature extremes are moderated by a space heater in the winter and a south breeze in the summer. A mini split system would allow comfortable year around shop usage.
Tom
This woulbe a good answer
I currently work in an uninsulated garage. It us unheated in winter and just have fans for summer.
This would do great with some insulation!:smile
1 - 20 of 215 Posts
Status
