1 - 6 of 6 Posts
· Registered
This looks like a great place. I'm pretty new to woodworking. I live in
New Mexico. My first question, I want to build my own router table and I
thought maybe some one could give me some advice
as far as a good size for a table top model as my shop is not very big.
Or a link to some plans, I've seen a few but lost track of where I found them.
Thanks, Walt
· Registered
Greetings Walt.
I'm also a big fan of benchtop router tables. A good size seems to be about 18x24". This is less of an issue if you make your own fence. I have a couple of commercially available fences designed for benchtop tables and 24" is a good width for these.
As far as plans... there are billions out there on the web. I'll post a few. A good strategy is to use mdf for the table; if you glue up two pieces of 3/4" stock you'll get a very nice table. My local Home Depot has 2x4' sheets of mdf for $6. This would be more than enough for a table.
Most folks like to cover the table top and bottom with formica or other laminate. For my next table I intend to use hardboard masonite) for the top.
If you do a search on these forums you'll find lots of great user's router tables.
http://www.rd.com/americanwoodworker/article.do?siteId=2222&categoryId=7002&contentId=628
http://www.woodsmith.com/issues/156/extras/fold-away-router-table/
http://www.rexmill.com/ (in "projects" section)
This is a good plan available for purchase but you should be able to find some good freebies:
http://plansnow.com/dn3062.html
Have fun,
Michael
· Banned
Walt, one of the simplest table designs is also the easiest to use, and that is The Router Workshop table. The plans are $4 from Oak Park. You can build the table and a base cabinet from a single sheet of 1/2" plywood. Overall size is 30" x 16", and the neat thing about this design is you can eliminate the base cabinet and side storage under the table and have a great little portable table to set on your bench.(18-1/2" x 16")
1 - 6 of 6 Posts
