1 - 6 of 6 Posts
Discussion Starter #1
New to the Site, just started playing with the router I've had for years, It's a Ryobi 163. Bought an inexpensive Dovetail Jig, MilesCraft Universal Base with an assortment of Bushings.
Here's my problem, the 1/2" OD Bushing, does not fit in the 1/2 template fingers. Did I go too cheap on the jig?
Are you sure they are both 1/2", try measuring them.:confused:
Super Moderator
Hello Jim, glad you found us, it's great to have you as a member of the community, welcome to Router Forums.
Agree with Bob make sure you are not dealing with metric
Some of the jigs are 7/16" not 1/2"....
...or they require 7/16" guide bushings..
Discussion Starter #5
The Jig is stamped as 1/2" and the bushing is a 1/2 OD. Measuring, it looks like the jig is slightly smaller than 1/2".
Can I use a 7/16" bushing and just make sure I go edge to edge?
Hi Jim, what does the manual say? If it says 1/2" for both, [template and bushing] then something is wrong. Take it back.
Also check you 1/2" bushing. It may be off size.
A forum member I spoke to about this did not believe that a 7/16" bushing was called for...LOL.
There should be one in your bushing set. Try it.
1 - 6 of 6 Posts
