Here is a quick reference to different types of guide bushings.
Photo 1:
Top left: Old style Bosch. Installed by removing the bottom plate of the router.
Bottom left: New Quick change style Bosch. Installed by dropping into place and sliding a lever. Note the quick change adapter with a PC style bushing installed.
Bottom center: Typical Porter Cable base plate with bushing installed.
Bottom near right: PC style bushing.
Bottom far right: Rousseau mounting plate installation bushing. Note the removable top ring locked in place with an Allen screw. Guided by the template with a straight cutting bit installed; removes the main cut out for the router. Removing the top ring reveals a smaller guide used for cutting the lip that supports the plate.
Top right: Typical Craftsman router with guide bushing. Bushing is plastic and held in place with 3 screws.
Photo 2: Craftsman bushing; sits on top of the sub base plate, 3 screws.
Photo 3: The larger Oak Park/Lee Valley style on the left; PC style on the right.
Photo 4: Reducers in both styles.
Photo 5: Milescraft kit with base plate, bushings and an adapter to use PC style.
Photo 6: Trend metric or Imperial guide bushings in HD plastic, steel and the T3 adapter for PC.
Photo 7: Trend UniBase/bushing which will fit most routers.
Photo 8: Makita bushing; attaches with two screws on older models, new models have a quick release lever and require no screws. Bushings work with either style.
Photo 1:
