Dimitri Guest said:
Yes! I am interested in your process to flatten the top of the chest. I have all the hand planes needed i.e #7,#6,#5,#4,#3. Please describe the process if you can step by step.
thanks,
Dimitri
OK,
I will assume since you have all the planes that you must know something about planes. But, let me go over this quickly,
1) the planes must be sharp
2) the blades must be square
3) the planes must be adjusted (cap iron, frog, centered and depth)
You must also have a straight edge longer then the chest top. Depending on how big the chest is a square might work or you might have something like that that will work.
If you have not sized the top yet please donot do so. Sizing is the last thing to do.
For now lets say you have selected a top and bottom. You must locate the high spots, using the straightedge find the high spots and mark them. Start with the bottom to give yourself some additional practice. You want to plane off the high spots. You must try to plane with the wood grain, since this is a glued up panel (right?) this might not be easy. You will want to have the plane set to take a very fine cut 1/32 or less. (You should set this up and test on a separate piece of wood..... you want a long thin strip of wood (very thin).) The plane should be held at a slight angle to the grain so it shears, this is a thing you feel and hear when it is right, it is a "zip" sound. Hit all the high spots and again check with the stg. edge. Make sure you do the diagonals as well. Use this method until it is very nearly flat. Then start with the sole on the wood just before the blade and make long smooth strokes with the grain. As it gets flat the ribbons should be long, wide and continuous. Each pass should over lap the previous one and you may want to adj. to an even finer cut. The surface should be getting flat and may look shiny as you finish.
The other side is done the same way. Depending on grain directions you might need only scape to finish or some sanding might be needed. At this point you should be done and can size the top.
If you at anytime get tearing try making the cut thinner or go back to going at a slight angle, or maybe try coming at the wood from a different direction (180 deg.).
Let us know how this comes out.
Ed
