Hello and welcome to the forum,Kitui
Lets see if can find some one help you
Using a template that's going to duplicate the finished shape, you clamp the template in place and use a bearing-guided bit (after roughing out the handle) to cut to finished size.Thanks, I checked most of the video in youtube and forums. I saw the youtube video a while back but there are few details. I need to use a template of some sort because I need to make 26 handles. So what kind of bit should I use: spiral straight, upcut, downcut, diameter, etc. Thanks for helping
Here's a link to a site that shows various designs of cutouts similar to what you show.
https://www.google.com/search?q=handle+cutout+in+drawer+face&rls=com.microsoft:en-US:IE-Address&tbm=isch&source=iu&ictx=1&fir=kY6kt4Hs1yxi-M%253A%252C3SkBrK_9_3mNAM%252C_&usg=__korHTYyIBoprYrxwMkyVMzQCCx8%3D&sa=X&ved=0ahUKEwiErqnrg_HYAhUEsFMKHSKPAQoQ9QEIKTAA#imgrc=rC2hV-y7hMhkCM:&spf=1516812120871
There's one link in there to a YouTube video that shows a jig for making the cutout with a router but doesn't give any dimensions - I would think you would make it based on a hand width at the knuckles, maybe something around 4"? Bear in mind though that the whole hand doesn't necessarily have to go into the cutout, although the hand (mine at least) is about the same width all the way down. The jig shown in the video is a little bit overkill, I would recommend making the cutout with a simple template having cleats that locate on the top edge of the drawer front, and also make it with a radius between the cutout and the top edge of the drawer - mark a center line on the template and drawer front, clamp the template in place and make the cutout. While you could make the cutout in one step, I personally would rough it in slightly undersize with a jigsaw and then just use the template to clean it up to final size. Finish by running a round-over bit around the recess.
https://www.youtube.com/watch?v=JfxBDdszXeI
https://www.youtube.com/watch?v=kYrh4IiJaWo
