Harbor Freight 6" Rabbeting Jointer
1 reading
102K views 28 replies 16 participants last post by  DesertRatTom
This is a new addition to my shop. I was comparison shopping for an inexpensive jointer and was curious as to how much value there would be in a unit regularly priced at $249.00. This unit has a 1 HP motor and draws 8 amps @ 110VAC. There are 3 knives in the 3" cutter head and both the infeed and outfeed tables are hand wheel adjustable. The overall length of the table is 42.5", there is an integral stand with a dust chute but no dust collection port.(I plan to build my own.) A small blade adjusting gauge and wrench is included. Replacement blades are $9.95 a set. This machine costs considerably less than jointers offered by other companies, and you have to wonder if it is worth the money. I acquired one of these units in a trade, and it is in pristine condition. I will be running it through the paces with a variety of woods and will report my findings and give this tool a rating over the next couple days.
#3 · (Edited by Moderator)
Hi Mike
I have the same one but with the long adjustment bars on both ends, it's a great machine, the 4" dust port I got for it came from Rockler and with 4 screws it's on . :)
I know you know this but don't run it without the dust port and the vac. system running the chips will go around and around and chip the blades if you don't pull them out of the machine.
I'm on my 4th set of blades and now using the last good part of the (2") of the blades on the 4th set ,Dam little rocks and sand put chips in the blades so quick. :( I always check for metal but the little rocks don't show up.)
One of the many draw backs of using old lumber and trying to reclaim it.
I did put one of the new type of V-Belts (link-belts) on it to try and get it run smoother and with less noise and it did help...
All in all I would rate it 4 out of 5 stars :) can't beat it for the money.
Bj :)
I'm with Bj on a great deal for the money. You can put your expert touch on tuning it up and have a good machine. I've gotten tools that the previous owner complained about. Then, when nobody is looking set it up right. At times the difference is drastic. Good luck with it and pick up some pushers.
#5 · (Edited by Moderator)
Hey Mike
Talking about push blocks, here's the one I use on the jointer and it works the best :)
I have many push blocks and this one will let you keep all your fingers in place and help you keep the stock flat to the bed... note the 2nd knob up front.
Bj :)
#7 · (Edited by Moderator)
challagan said:
BJ was this machine a booger to set up the infeed and outfeed and put in new knives? Just curious.
Hi Corey
Duck soup to setup and replace the blades..
But I do cheat a bit, my son works for Car-Toys and I get alot of BIG speakers from him and I take them down so I can use the BIG magnets for jobs like replacing the blades on the jointer.
The one I use is about 6" dia. and just set it on the bed and it sucks the blades right in place then I turn a screw and they are set to run. :)
The one below looks like the one I have but without the switch tower.
http://www.grizzly.com/products/g0452
Blade installer, but you know me cheap SOB so I make my own :)
http://www.grizzly.com/products/g3360
One below is for Mike
Bj :)
Thanks to all for their comments. The 10 hour days at work limit my time in the shop but this weekend will see the sawdust flying. The jointer runs very smoothly. I made a couple test cuts and am pleased with the performance so far. This will be a very good addition to my shop, and for those of you who don't already know: "I like good deals", and the $120 I have invested in this machine will pay great dividends.
Bob,I think you may well have solved my problem of fitting the cutters, my 20 odd year old jointer appears to be identical to Mikes. It's always been a tricky job, I shall let you know in due course.
#14 · (Edited by Moderator)
John, this machine will cut a rabbet when you set it to do so. The rabbet is formed by moving the fence to the front of the machine and running the board through on edge. I would never bother doing this since the job is so much faster with a router.
After running many boards through this machine I am very pleased with it. I was in a hurry the first day I needed to use it but still wanted to use the dust collector with it to avoid the mess so I fastened the dust port to it with a Rockler band clamp. It worked like a charm. If I had more space I would love to leave all my machines hooked to the dust collector. No way that will happen in my garage, so every job means fastening the hoses.
#16 ·
Great deal Mike, I have seen HF be "cheap" and then cheap! If one knows what they are looking for HF is not all bad at all. I just picked up the Delta for 200.00 through one of Rocklers sales. I will be checking out HF for dust collection and band saw some time in the future, after the money spent the last two months, it will be the distant future!!
Honey is great and understanding but not "that" understanding sometimes. One thing she has agreed to is me moving the shop from upstairs to the walk out basement, and not the down stairs garage but into the area that is almost equal to a two car garage with windows and French doors that are walk out to the lower driveway I will need to do a lot of work there to get it finalized but I can use it as is for now and work one section at a time.
Reactions: DesertRatTom
#29 ·
I think Harbor Freight has their DC unit on sale for about $199 during June. Having that DC has really made my shop cleaner and safer healthwise. Your wife is likely to appreciate your reducing the sawdust you track in and that leaks into the rest of the house. In the mean time, I hope you are using a good mask. That sawdust will ruin your lungs pretty fast. Have her read a couple of strings on dust collection. It is worth a bit of debt to protect your ability to breathe.
Had this Jointer for a about 3 years now and its been a champ for me. I recently decided it was time to sharpen the blades on it and saw it was discontinued and there was longer replacement blades for them. I was hoping to have a second set on hand to rotate through. I was wondering if there was any other compatible blades on the market?
This is my solution for dust collection: a piece of plywood with a 4" plastic dust port attached. I put some self adhesive weatherstripping between the plywood and the machine. This works like a charm.
#24 ·
Hey Mike, I don't come up with any jointer at HF. Only two hand held and their 12" planer....I'm going to keep my eye on the "Trader's Guide" type papers though. Glad you were able to pick that machine up.
